10-09-2015 07:15 AM - edited 10-09-2015 07:22 AM
I would like ask, is it possible to make a buffered pulse train generation application using cDAQ-9181 and NI 9474 as hardware?
I have an application, in which approx. 18 bits are generated, with pulse width of ech bit varying approx. 300...500 us range. One microsecond resolution (at least 10 us) would be needed to adjust pulse width. According to specifications, NI 9474 should be capable to do it. The withd of the pulse high and low states should be varied independently. An example of the situation is shown in the figure below (figure was taken from daqmx help, Buffered Pulse Generation).
Is there some kind of software buffer in cDAQ-9181 orNI 9474, which could be utilized to first load this "waveform data" to DAQ memory, and the trigger it to execute to needed pulse pattern?
Do I have to use "Ready for new value"-propery to update pulse parameters on fly? I tried already this, but the result was not succesful.
Daqmx-help also mentions the use of two counters in some cases. Is this a potential solution for my case?
By this far, I have been succesful to produce single finite pulse (based on "Gen Dig Pulse Train-Finite.vi" LabView example in Generating digital pulses gategory) or series of identical pulses.
Best Regards,
Jukka
10-12-2015 03:42 AM
Dear Jukka,
This should be possible, you have to take care about the different rate of array input and pulse train output.
A good design idea would be to use a "producer consumer loop" (http://www.ni.com/white-paper/3023/en/). You can find this in the template selection creating a new VI.
If you are just interested in the pulse train output you can take a look at "Counter (Buffered) - Continuous Output.vi" in the example finder.
Please let me know if I can help you further.
Luigi
NINL
10-12-2015 07:18 AM
I was able to produce a buffered digital pulse pattern using digital waveform. See figures attached.
The problem in this solution is that only 10us resolution is achieved, when 1us is needed. So, 100k sample rate works, but 1000k seems not work.
Any suggestions for improvement?
Jukka
10-15-2015 02:36 AM - edited 10-15-2015 02:37 AM
I finally managed to create a satisfying solution.
Here's digital waveform creation (data is first Manchester coded).
Here's pulse train sending
And front panel
This code is used in application, in which control commands (DALI forward frames) related to lighting controls are tested (standard iec62386).
Jukka
