NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
clint100
AO Sample Clock PFI5 on PXI_6723
Is there any example code on generating a pulse train on PFI5 of a 6723 in Labview 2009??  I couldn't find any.
Member
margasan
Re: AO Sample Clock PFI5 on PXI_6723
Hello Clint,
If it is possible to route the signal ( counter output) to the PFI line 5 should be done using any of the methods listed in the link below:
Internally Routing Counter Signals in LabVIEW
However the 6723 routing table shows that there is no direct on indirect route between the counter´s output and PFI 5, you may try it.
Regards
Mart G
Member
clint100
So why is it labeled PFI5/AO SAMP CLOCK??  What exactly does that mean??
See attached.
Active Participant
Brad_K
Hi clint100,
The NI 6723 is based on the DAQ-STC ASIC, which can input most timing/triggering signals from any PFI terminal, but can only output specific signals to specific PFI terminals. For example, PFI5 can be used as an input for the counter source, counter gate, AO start trigger, AO sample clock, etc. The only signal that can be output to PFI5/AO SAMP CLOCK is the AO sample clock (i.e. the DAC update signal for hardware timed generations).
Brad
Brad Keryan
NI R&D
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
