05-22-2014 09:34 AM
Hello
I have a NI9401 on a C-DAQ9178 on slot 5. One encounter is connected to the 9401 and i created a task for the angular position measurement.
My problem is that I want to have continuous samples but I din't get the right clock source, so only 1 sample on demand works currently.
Does anyone have an idea how to configure the clock source?
Thank you very much in advance,
Martin
05-23-2014 03:45 AM - edited 05-23-2014 03:45 AM
Hello Martin,
there is an internal frequency output that can be used for the clock.
Attached an Example hope this helps
05-26-2014 02:00 AM
Hi Duffy,
thanks for the vi. I think I understand now how it should work, but my problem is that I have to configure it in the MAX, because I've to use the signal in DasyLab, and this doesn't work. If i select continuous data in the task, i have to select a clock source under Advanced Timing and none of them works.
05-30-2014 06:41 AM - edited 05-30-2014 06:43 AM
Hello Martin01
so the situation is, in that case, the aquire only can be done with the samplerate from DaisyLab.
Sorry for this, but you can´t implement the continous feature like in our task described.
