NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Asmat
Re: Watchdog Agent Prognostics Toolkit
Dear Farrell,
I am a student of M Tech from Bangalore. I am doing a speach recognition project using LabVIEW. This requires Gaussian Mixture Model Functions.
I have installed Watchdog Agents Prognastics Toolkit on my laptop along  with LabVIEW 11(Advanced Signal Processing Toolkit,Sound and Vibration Measurement Toolkit, Mathscipt RT module, basic LabVIEW tools), gxml_140_installer on Windows 7(OS is installed in C-drive ). After installation I searched in LabVIEW search option  for Watchdog Agents Prognastic Toolkit related icons(Gaussian Mixture Models), but they were not found. I couldnot even find gxml library related icons/files. I checked out in Labview11/examples, but I didnt find them(I have installed Labview in F drive) Please help me.
Active Participant
Doug_L._Bear
I imagine that because LabVIEW is installed on your F Drive, the GXML and Watchdog Agent instllers did not install properly to the LabVIEW folder.  Check to see if you have the following folders on your computer:
C:\Program Files\National Instruments\LabVIEW 2011\vi.lib\addons\Watchdog Agent
if this exists, your installer misinstalled to the C drive and you will need to reinstall making sure to point to the correct LabVIEW folder during installation.
Otherwise, check your LabVIEW\vi.lib\addons folder on your F Drive for the Watchdog Agent folder.  I would imagine it is not there if you are not seeing the VI's in LabVIEW.
The same thing should be done for GXML as I imagine it is having the same issue.
Doug Farrell
Product Manager - Condition Monitoring
National Instruments Condition Monitoring
Member
Surajkamal
Is there HMM toolbox available in the toolkit?
The link
http://www.cicr.com/docs/actividades/EFEN/Sound%20and%20Vibration%20Overview%20MCM%20focus%20Paulo.p...
shows so, but in NI product datasheet there is only GMM is listed.
Is it missing, not listed?
Active Participant
Thanks for the post Surajkamal,
The slide 64 from the link you reference, does list HMM, yet as a function that is NOT implemented in the Watchdog Agent(tm) toolkit.
We are working with a group within the www.imscenter.net, to determine how and when we might add it.  So it is not available just yet.
Preston Johnson
Global Program Manager
Asset Monitoring Systems
Vibration Analyst II - www.vibinst.org
preston.johnson@ni.com
www.ni.com/mcm
www.ni.com/soundandvibration
512-683-5444
Member
Surajkamal
Thanks very much for your reply..
Anyway I am working with an HMM design (in C++)and trying to port it to LabVIEW
Just queried because if the tool box is available there of the shelf
I could evaluate it on hardware(cRIO) without taking much time
Member
Asmat
Thanks for your suggestions.. I installed LabVIEW, GXML installer and Watchdogagent on C drive. Its working fine..
Ayesha Banu
Member
Neo6
Hello Doug Farrell,
May I know the current status of this toolkit ? When I tried to download, its not showing as evaluation version and also it costs nothing.
Is it still in development or How many days can I use this evaluation version ?
Regards
Neo.
Active Participant
Thank you for your post Neo,
Currently the Watchdog Agent(r) Prognostics Toolkit is offered as an evaluation software.  There is currently no cost, and the license restricts use for evaluation purposes only.  We are working to post a next version, which will allow for deployment in the field.  This is still a few weeks away.
We look forward to your feedback and additional questions.
Preston
Preston Johnson
www.ni.com/mcm
512-683-5444
Member
Nitin.sg
Hi Doug,
I wanted to know where can i get more examples on Radar Chart using Watchdog prognostic tool.The evaluation version has only one example and i am not able to run it.Please help me.
Regards
Nitin
Member
Chuan
Hi, Nitin:
The radar chart demo in Watchdog prognostic toolkit was designed specifically for multi-component performance assessment in a system level. It is supposed to be used with a mechanical system(e.g.,rotor kit) and cDAQ. What problem are you trying to solve?
Chuan
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
