NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Active Participant
Christian_L
Re: Customizing the Tag Configuration Editor (TCE) for Machine Control
The e-mail address in my previous post has been corrected.
Christian Loew, CLA
Principal Systems Engineer, Embedded Systems
Please tip your answer providers with kudos.
Member
Steve Sexton
Re: Tag Configuration Editor (TCE) for Machine Control
I am trying to open the 'Simple Machine Control Example'  MCA_Tag Configuration.xml file and I get the error below and after that I have to go to the task manager and end the TCE.exe.  Any help would be great.
Steve
Error 537020 occurred at an unidentified location
Possible reason(s):
While loading a configuration file an error occured.
The class tagRoot tried to make the class ReadTWriteF a subnode, but is not in the allowed subNode data
Member
Daniel_E
Hey Steve,
What versions of the example and TCE are you using?  I just downloaded both tce_installer_202.zip and simplemcaexample202.zip directly from the respective webpages, unzipped and installed tce_installer_202.zip and unzipped the simplemcaexample202.zip.  I ran the TCE, selected File>>Open and select the newly unzipped MCA_Tag Configuration.xml.  This doesn't give me any issues.  Is this the process you are following?  Did you change anything in the XML file?
I did try and open MCA_Localization.xml, which gave me the error you explained.  This makes sense as this xml file is intended for a different configuration editor.  It did also hang the TCE like you described.  I will add that to our internal list to make sure it gets fixed in future releases.
Daniel Eaton
Systems Engineering
Embedded and Industrial Control
Member
Steve Sexton
After an uninstal and reinstall, it works.
Steve
Member
wireman
Hey, TCE and the rest of the Reference Architecture is great! It saves lots of work developing our own mechanisms to handle the many underlying tasks. Thanks so much!
It would, however, be nice in the TCE if we could easily reorder Tags in the tree, or move a tag from one folder to the other by dragging and dropping.
-Nate
Active Participant
Brian_K.
Actually the drag drop feature and reordering is already in the TCE, you just have to press the control button.  I intended to put text on the front panel that would say as much, but I forgot.  Hope that helps and thanks for the feedback, and if you have any more ideas that would be great.
Brian K.
Member
wireman
I frequently experience hangs with the TCE where I have to End Task using the Windows Task Manager. It occurs at least once or twice a day each day I am using the TCE. Does this happen to anyone else, or am I doing unusual things with it?
Active Participant
Brian_K.
Can you trace it to any particular action?
If we can't, then maybe we should run the source code instead of the EXE, and hopefully the hang can be debugged just by seeing where the code gets stuck at?
Brian K.
Active Participant
Brian_K.
I did recall a bug that looks like a hang.  If you hold the control button down (or any button down) while the focus is on the tree control, it fires many events. And those events take a long time to get processed (like a minute), so it appears to hang.  If you wait like 2 minutes do you regain control?
Brian K.
Active Participant
Chuck_81
Hi all,
I've just noticed that the TCE source code has a dependency from Unicode VIs that are expected to be placed in the <user.lib>\Tools\Unicode folder. In order to solve this dependency you must dowload them from this page:
https://decibel.ni.com/content/docs/DOC-10153
the attachment you have to dowload is LV_Unicode-110-lv2009.zip
Fabio
Fabio M.
Embedded & OEM Systems Engineer
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
