02-17-2014 10:00 AM
02-17-2014 06:48 PM
Thanks Brian for your quick response and for suggesting CEF.
As you wrote, " firstSuperNodeWhoIs.vi " search backwards in the tree, the supernode ( parent node ) of a specific class or alternatively up to the supernode stop class .
If you analyze the diagram, there is already a condition that avoids the problem that you refer to, in fact, before moving to the next upper level, it is checked if the current Node has a SuperNode=" Node0" (the node TagRoot).
In fact in my debugging, I could see that the problem has always occurred when the class was asked hmiFolder its supernode.
In my opinion, the problem is not resolved by the control "valid class reference", because I can say that the class reference returned is the correct one.
In fact, I first followed the research of "tagRoot" node from ".\TCE\NetworkTag\BrowseBindToTag.vi " and took note of the class reference to tagRoot,
then I did the same thing with the request from ".\TCE\TagFolder\menuActivate.vi" and I verified that the class reference should have the same value .
The problem is something else but I can not figure out what it might be due.
03-13-2014 08:41 PM
Hi Fabio, I have down loaded the LV_unicode files to load the TCE source code in 2013. There seems to be other dependencies. these are example of VI's in libs that cannot be found
Can you please indicate any other libs that need to be installed?
Kind Regards
Malcolm Marker
03-14-2014 11:04 AM
05-20-2014 08:40 AM
I am using TCE to set up an XML file in oder to run a CVT. I am only just setting up the file, and every time I run my CVT vi it keeps giving me the error:
"Error 1103 occurred at Unflatten From XML in Current Value Table.lvlib:Load Tags.vi->Host CVT.vi->Host.vi
Possible reasons: The XML tag describing the type of data is not recognized."
Has anyone seen this before? I would assume the TCE would know how to write the data type so that it can be recognized.
Any help would be appreciated.
05-20-2014 09:30 AM
07-29-2015 05:08 PM
Do you know where I can find a schema definition for the XML structure supported by CVT 3.0? I could just create my own XML config file and format it manually, but I need to know the expected file structure.
