10-16-2008 12:14 PM - edited 07-24-2016 10:43 AM
Please provide feedback, comments, and questions on A Reference Design Library for Simplified XML Generation this thread.
02-04-2009 05:55 PM
Not compatible with LabVIEW 7.1.
Tested.
I have a plan to use MSXML activeX. Is there any other idea about using XML in 7.1?
02-09-2009 12:07 PM
06-11-2009 10:44 PM
Dear Friends,
Do you have any idea to generate XML schema in LabVIEW 7.1.
If you have any resources or links regarding this, please send it.
Thanks in Advance
MRK (CLAD)
07-16-2009 07:19 AM
I would really like to use the simplified XML library but unfortunately I'm on LV8.5.1 and not on LV8.6. How can I bring this library to my version of LV or could anyone supply a LV8.5.1 version?
Thx a lot!
05-10-2010 04:12 PM
I created a simple vi (see attached) in 8.6 based on the introduction on ni website about this library. when you run it, got error (2602) while creating the second root for xml file. any idea of why?
thanks,
Sue
02-01-2012 10:08 AM
there is a problem with "Create Tag - Child with Text.vi". A reference to a Text Node is created but the reference never is closed. This can lead to memory problems if used extensively.
06-14-2012 05:58 AM
I have painstakingly scoured my code for any open references, but to no avail, I still notice a decrease in performance after some amount of consistent usage. Does anyone have any tips for either searching for unclosed references or even a method to reinitialize the XML engine?
Thank you.
07-22-2016 04:33 PM - last edited on 07-26-2016 09:03 AM by Christian_L
A VI Package version of this library is now available In VI Package Manager from the LabVIEW Tools Network. It supports LabVIEW 2013 and later.
