05-16-2014 09:28 AM
08-18-2014 01:45 PM
I'm using Labview 2013 + RT + fpga. Which version of the STM should I be using? Different samples / templates seem to use different versions and go into a compatability mode.The On-line documentation states that Version 2.1 is the latest but the JKI Package manager shows a 3.006 as the latest. I presently have 3.006 installed.
08-18-2014 05:31 PM - edited 08-18-2014 05:31 PM
You should be using the version on the LabVIEW Tools Network (VIPM), that is, version 3.006. It is compatible with LV 2010 and newer. Please let me know if you have any problems with the templates with this version.
I'll update the STM Documentation to reflect the newest version. It may take a few days for our website to reflect these changes.
Sincerely,
09-18-2014 12:59 PM
What would be the best way to modify and use this for a re-connectable STM send and receive loops? Or is there a different approach for that ?
DennisR
09-18-2014 01:19 PM
What I would like to see is the STM implemented using the Network Streams. That would have the reconnecting setup already built in.
09-18-2014 03:02 PM
Well, the devil sits in the little details but in principle a reconnecting client library would in the first place implement some retry mechanisme whenever it sees an error during communication with the server. You would have to treat all TCP errors that the LabVIEW nodes return, except sometimes timeout depending on the protocol step you are in, as well as errors in you protocol layer handling when receiving illegitimate data packets as an indication to close the connection and then reopen it. This generally requires a more involved setup as each connection also needs to somehow allow to retrieve the actual address (and port) information in order to be able to reconnect.
On the server side the handling is a little simpler. Whenever you see an error (except timeout errors when waiting for commands from the client) you simply close the connection. This will cause the client to receive a "connection closed by peer" error and then to attempt a reconnection with the server.
10-24-2014 04:54 AM
I would like to communicate with a cRIO using this library, but from a C# program.
Is there any librrary or a .NET based example of a STM client?
Pedro
10-27-2014 10:08 AM
Hi Pedro,
There is a MSVC++ Example using STM, found here. I also wrote an example for Visual Basic .NET, which is not 100% complete but may act as a good starting point. It is attached.
10-27-2014 12:55 PM
Thanks Julianne, that is very helpfull!
Is there any plan to include a password authentication in future releases of STM library?
Pedro
10-27-2014 01:15 PM
There are currently no plans to add it. However, I have added your request to the feature request list for STM so that it can be considered for the future.
