NI Home
Cart Cart | Help
You are here:
Reply
Member
ninjaphil
Simple Dual Redundancy
Please provide feedback, comments, and questions on the
Reference Design for Simple Dual Redundancy
in this thread.
Member
toddho
Re: Simple Dual Redundancy
Can not get it to install in 8.6.1.  After the instillation screen asks where you want to install the files up pops another screen that says no software will be installed and the next button is grayed out.?
Todd
Member
Doug_S
If you previously installed it for another LV version, I believe that you must uninstall it before reinstalling it.
Member
toddho
Yes, you are completely right.  I now have it working.  Thank you!
Does anyone know if there is something like this already written for TCP/IP?  I will be trying to use this not for compact RIO but on servers.  I am afraid that using serial ports may be hard to do... Hardware wise.
Todd
Member
LaRisa_M
How do you specify which controller will be the Primary and which will be the Secondary?
Product Support Engineer
Member
toddho
I think a start up configuration file assiging a functional global variable is probably the more eligant way but I just have two identical versions but with a "Primary" boolean control setting the functional global that I change on the primary and the non-primary.  Then in my decision making it checks to see if it is the primary and takes or gives control accordingly.
Hope this helps
Todd
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
