04-26-2017 02:14 AM
hi David,
i have couple questions here...
Please clarify...
09-27-2017 08:27 PM
I am using SPI waveform library for working with HSDIO-6548. I have sent 24 bits of data to one of the customer device. The device is working great. Now the problem is I have to send 384 bits of data to the customer device for burst read and write . Can you help me with some code so that I can send these number of bits to HSDIO using SPI waveform library
09-29-2017 12:20 PM
Dear David,
I would like to know if there is a way to implement sequential byte send to a single slave with variable CS idle?
I attached below the desirable timing diagram.
Thank you in advance
Afonso Plantes
10-06-2017 11:47 AM
Never mind, I have already solved it.
11-03-2017 03:14 AM
how can we control SS/ chip select line .. in SPI using HSDIO:
Is there any chance of making chip select (High) de-assert at middle bit of particular transactions without modifying the behavior of other signals (sclk, mosi, miso) in SPI Communication using HSDIO.
12-13-2017 05:38 AM
is this SDW can be used with NI 9402. David mentioned that
"We can only use the SDW waveform with a clocked digital I/O device"
I am really new with the labview and DAQ. please give me some advice
thanks
12-19-2017 03:01 AM
Hi Plantes,
Can you share with us how to set the CS idle time?
01-11-2018 06:03 AM
If you just want to send SPI data to a device (digital pot for example) the a 6509 works fine providing you don't need to send all the data very quickly.
In Labview configure a 8 line port as an output, use 3 of the lines for enable, clock, data. If there are 8 bits of serial data (plus start stop bits) to be sent, then make a sequence of 8 port writes (plus start stop). Then for each of the port write set the:
clock high & data (bit 1 value), write to port
wait a few mS
clock low & data (bit 1 value), write to port
wait a few mS
The repeat for the other bits.
As its a port write then the clock & data will be in sync. It may take some 60mS or more in this example to do the complete write, but it does work.
01-11-2018 02:21 PM
Hi rioriorio
I just changed SPI timing (ticks).Idle. Now, I can have differents CS Idles for my MOSI array.
01-12-2018 01:20 AM
Thank you Plantes
