Reply
Reference Library for Converting Between LabVIEW and XML Data (GXML)
Re: RESOLVED - Building Web Services with GXML
Wow Martin I'm glad you called tech support.  I don't think I would have figured that out.  Thank you for posting the resolution!  I have several projects in the pipe that will use GXML in a LabVIEW Web Service.
Jeff
Message 31 of 131
(5,610 Views)
GXML does not work with tables
The GXML parser does not seem to work with tables such as an array of clusters containing one string and one table does not work.
Message 32 of 131
(5,449 Views)
Re: GXML does not work with tables
Could you please attach an example VI demonstrating this?
Jeff Tipps
S&V Systems Engineer
Message 33 of 131
(5,443 Views)
Sorry my mistake, it does indeed work with tables.
Message 34 of 131
(5,440 Views)
Fast Parser does not work with arrays of unknown size
I have a large data structure (array[(string,array[][])]) that takes around 1 minute to do a recursive parse on an cRIO.  The fast parse mode
gives me an error because the array sizes are not known at runtime.  Is there a way to make the fast parse mode
work in such a case?
Message 35 of 131
(5,416 Views)
Re: Fast Parser does not work with arrays of unknown size
Can you please post an example code demonstrating this?
Thank you,
Jeff Tipps
Message 36 of 131
(5,415 Views)
Actually the problem is that the GXML data that is being generated and saved to the cRIO Flash is somehow getting its <cr><lf>'s messed up.  I will have to revisit in the morning and will post my results.
Message 37 of 131
(5,406 Views)
Highlighted
Thank you I look forward to your results.
Jeff Tipps
Message 38 of 131
(5,399 Views)
Ok, the problem was in the read/write file.vi primitive that I use to save and read the GXML data from my target devices.  The default for the file vi's is to convert EOL to LF which makes the data incompatible with the GXML parser.
Message 39 of 131
(5,395 Views)
Are you using the the GXML Read/Write File VIs?
Jeff Tipps
Message 40 of 131
(5,393 Views)
