07-23-2012 02:23 PM
Dear, I need an I2C communication between a microcontroller and a Labview VI, I have a PCI-6251. I got a SPI communication between the microcontroller and the PCI-6251, but have no idea how to communicate using I2C. Anyone know how to do? Is it possible? Is there an example available?
01-22-2013 09:56 PM
I have used developed a small program to simulate a transmission and reception using the function pallette using the IDW function. The program works only when the sample rate is equal to or greater than 1M.. But i need my application to run at 100k.. I figures out that i need to make a few modification in the init.vi but dnt know what modification to make. Help plz..
08-06-2013 04:41 AM
hi, can you help with your spi code. I have bben trying but no success
11-12-2013 10:11 AM
Hello all
is it possible to use this library VIs with sbRIO and how please ?
thank you
Mustafa
09-15-2014 06:55 AM
I use the library I2C digital waveform with a PXIe 6556 to check the protocol with my chip.
The chip was verified with the NI USB 8452 and work.
I try to build the trame with the library I2C digital waveform and generate the signal with a PXIe 6556.
I can write the question with the PXI and read the response with the USB (valid answer)
When I write the question with the PXI and read the answer with the PXI I read only the address of my chip and a lot of FF
I don't know why ? how ? ....
my code attached
the graph answer
11-09-2016 11:11 AM
Raj,
Can you provide the details of how you were able to blank and insert delays? I'd like to have a short delay in between each byte that I transmit to make it more human readable when looking at the signals on an oscilloscope.
07-26-2019 03:56 PM
Hi David,
I try your I2C digital waveform driver with PXI 6552, is possible to change the clock polarity? I try to use the driver to program the DAC7678, the component send data on the rise time of the clock.
Thank you for all
Francesco B.
04-13-2020 12:34 AM
For I2C write/read, SDA must be transfer from high to low during SCL is high . But In this lib , during start bit , SDA remains at 0 only. How to overcome this issue ?
03-10-2021 03:29 AM
I use this Interpret HWC Samples - I2C .vi , if i set fixed register address, the data interpreted is right. but if i use a loop to read multiple byte, the data interpreted are wrong except this first byte. I check the waveform , they are right. How to fix this issue?
Thanks!
Denny
03-10-2021 03:37 AM
Thanks!
Attached is the waveform and interpreted data array, 2nd byte is wrong.
Denny
