07-07-2014 02:51 PM
I've found a documentation error in the CVT. Not a big impact. Delete Group.vi seems to have the same documentation as Group Tags.vi:
07-08-2014 07:25 AM
Thanks, I've added that to the known issues list here:
07-11-2014 01:01 PM
I am curious to learn of experiences of actual CVT implementation when used to serve applications that;
(i) can tolerate time delay in the order of minutes or even hours (i.e. non-time critical)
(ii) and for applications that can tolerate time delay in the order of milliseconds (time critical).
Where both (i) and (ii) are serviced using a single CVT implementation.
Scenario: An application with multiple parallel 'process' controllers that needs data at rates of 50 Hz for example, where the same dataset has to be published to a UI (at rate of 1 Hz), transmitted to a remote database for automated recording (at a rate of 0.5 Hz maximum) and also retrieved by an application for fault detection (at a rate of at least 45 Hz). Let's say that this dataset has a size of 100, and the process control application needs only 10 out of the 100.
If you've had a requirement for data reuse similar to the scenario above;
I have implemented a variant of the CVT by applying the same concept of tags et'al for data retrieval. However, I have used different means to get the data to consumer applications depending on whether they are time critical or not. Under the hood things are tailored to my application but I am curious to learn of the experience(s) of anyone who has use the CVT for my research studies.
Thanks in advance for your response
07-11-2014 08:48 PM
Well, we've definitely used it internally without issue. I can't go into details on specific applications, but the use case you describe is exactly what it was built for. Consider the designs discussed here:
https://decibel.ni.com/content/projects/cvt-based-reference-designs-for-machine-control
To answer your actual questions....
1.
Computational load will be proportional to data accesses if using the fast API, and I doubt data access would be more than 5% of an application. FGVs are lightning fast, and for a lot of these processes you can use the extremely fast group API. Ive only seen performance problems when people hit a particular pattern of using the normal by name API in a for loop with a bunch of tags. This requires the lookup process, which is slow, on every iteration.
2.
Can you clarify, I'm not sure what you mean. Having multiple accessory shouldn't be a problem in the vast majority of cases. You can hit determinism issues if you have a logger that is copying huge amounts of data from the cvt while a high priority process needs it, but I've never really run into any myself. Configuration can cause problems as each tag must have a unique name. Dataloggers don't care about this but control code could have conflicts.
3.
Generally cvt if we need this sort of application, as we just prioritize everything and test it to the extent we are comfortable with performance. we recently released something we call cvt-on-the-wire, internally, which can be used with queues to pass data around with more determinism. Link is here
https://decibel.ni.com/content/docs/DOC-36995
Daniel
07-14-2014 07:22 PM
We'd like to direct most future questions to this project location:
If you believe you will be better served by posting here, feel free to do so. It will still be actively monitored for the forseeable future. The community group above is the preferred location for new discussions.
Daniel
07-18-2014 07:37 AM
1.
Computational load will be proportional to data accesses if using the fast API, and I doubt data access would be more than 5% of an application. FGVs are lightning fast, and for a lot of these processes you can use the extremely fast group API. Ive only seen performance problems when people hit a particular pattern of using the normal by name API in a for loop with a bunch of tags. This requires the lookup process, which is slow, on every iteration.-- I'll downloard the reference API library to get familiar with some terms, otherwise I understand better that there are targeted APIs for different application requirements for data retrieval.
2.
Can you clarify, I'm not sure what you mean. Having multiple accessory shouldn't be a problem in the vast majority of cases. You can hit determinism issues if you have a logger that is copying huge amounts of data from the cvt while a high priority process needs it, but I've never really run into any myself. Configuration can cause problems as each tag must have a unique name. Dataloggers don't care about this but control code could have conflicts.--this relates to a scenario where say, ten applications must retrieve data from the CVT at intervals of at most 5 ms, I anticipate there would be blocking going on at that speed if the applications are not prioritized (in terms of timing)?...from experience? My next steps are to do a prototype application using the CVT to see how it performs for my intended application.
3.
Daniel
Thanks for the detailed explanations
07-18-2014 06:27 PM
No problem.
To clarify #1, it will probably make more sense if you download the API, but the basic idea is that you shouldn't do this for API-specific reasons:
The preferred mechanism is to do this, and perform the lookup before you go into the loop:
Since this is preferred, there are even VIs to do this:
As for #2, I think benchmarking is the only way to be absolutely sure. That having been said, if you take a look at the benchmarks section here you'll see that the data access time is very small, so there is less of a risk that your processes will collide and try to access the same resource.
Daniel
07-21-2014 11:33 AM - edited 07-21-2014 11:39 AM
Hi Daniel,
I have had play about with the API and conceptually I understand what's going on, except for the aspect of extracting the CVT data from multiple VIs running on the same local machine. Asides using TCP/IP or UDP how else could the data be retrieved, because I "can't afford" to have a local server on the local host of the CVT? Any insights would be appreciated. If a PM is okay by you, I could send a bit of detail on the crux of the application I'm working on.
07-21-2014 07:23 PM
Sure, send away. Im not sure I'm clear on the issue here anyway.
Daniel
12-17-2014 01:35 AM
I use the CVTs for transfering data between the three loops of my RealTime-Application on a cRIO 9074. I control the process from a TouchPanel TPC-2012.
Is there a way writing or transfering the CVT-Tags directly from the TPC to the crio? So that I can use the CVT-Tags direct on the TPC? Until now I use network shared variables for this but it seem a little bit too complicate because I must write the shared variables first into the CVT-Tags and vice versa. I think that using the CVT direct has more performance.
Thanks for your ideas,
Christian
