02-26-2014 03:00 AM
Hello Matti,
great that you found the the mistake and that it will be fixed future!
Regards
George
02-27-2014 12:28 AM
CCC v3.0.0.3 tries to create CVT groups for both write and read tags in Client Init.vi, even if there are none. (It happens in Initialize Address_Index Lists.vi.) This causes an error to bubble up from the CVT v3.3.0.13 API. It can be circumvented by guaranteeing that at least one tag exists in each group.
02-27-2014 12:29 AM
Oh LOL. I didn't read the thread before posting. Looks like I'm not the only one who found that bug.
02-27-2014 12:37 AM
Yep, you're not the only one, but you narrowed it down better 🙂
Chris informed in his earlier post that there should be an update coming soon fixing this issue.
-Matti A.
02-27-2014 12:40 AM
No need to wait. Just add two tags to every service: DO_NOT_USE_WRITE and DO_NOT_USE READ. Put them in every client sync list. 🙂
02-27-2014 02:34 PM
The latest version of CCC (3.0.1.6) is now available on the LabVIEW Tools Network. It corrects the issue where at least one read tag and one write tag needed to exist.
Chris M
03-03-2014 04:27 AM
Hi Chris,
I can't find the new version of CCC yet. I checked from VIPM and the LabVIEW Tools Network.
-Matti A.
03-03-2014 10:43 AM
Hi Matti,
The latest version should be available through VIPM, but if it isn't showing up for you, it should be accessible directly from here:
http://download.ni.com/evaluation/labview/lvtn/vipm/packages/ni_lib_ccc/
All the packages on the Tools Network can be downloaded this way.
Chris M
03-03-2014 11:02 AM
Hi Chris,
Thanks for the link. For some reason the VIPM is showing the older version (3.0.0.3) only. I tried both upgrading the installed packages and checking for new packages from the network but neither way was I able to find the new version of the CCC.
-Matti A.
03-04-2014 09:17 AM
Now the latest version of CCC is visible in the VIPM also.
-Matti A.
