Components
CLIP Node XML Generator (CXG)
Please provide feedback, comments, and questions on A XML File Generator for LabVIEW FPGA CLIP in this thread.
- David
(posted by Christian on behalf of David)
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
Message 1 of 16
(17,925 Views)
Hi !
I've got a small issue using  the CXG.
When setting Min and Max Clock value, sometimes the min value disappears when validating max value cliking outside the box.
Is that a bug or am I doing something wrong ?
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
Message 2 of 16
(17,665 Views)
Hi Christian,
I already download CXG utility. However, I don't have vhdl code for test. Could you give me the the example you use (DemoClipAdder.vhd)?
I want to follow your steps in this article "XML Generation Utility for LabVIEW FPGA CLIP Nodes".
Ziva
Message Edited by Christian L on 02-18-2009 11:40 AM
Message 3 of 16
(17,649 Views)
 The ClipAdder.vhd file is included in the examples installed for FlexRIO in LabVIEW.
C:\Program Files\National Instruments\LabVIEW 8.6\examples\FlexRIO\FPGA Fundamentals\User CLIP\Adder
authored by
Christian L, CLA
NI - Austin, TX
Message 4 of 16
(17,635 Views)
Hi zyl7 -
It may be a bug in the UI code. We are keeping a bug list, but I can't give any promises on when (or even whether) the utility will be updated for minor issue fixes.  This application has dual intent:  to automate CLIP XML generation for most users' needs, and also to show how a developer or company might design such a tool for their custom purposes.  You can treat it as a rubric for creating an automated XML generation utility of your own; my recommendation is to download the source and edit it to suit your needs appropriately.
David Staab, CLA
Staff Systems Engineer
Message 5 of 16
(17,629 Views)
I just download this and tried running the exe but always get this error after I add the port list and click on next:
Error -2677 occurred at Invoke Node in Simple XML.lvlib:Create Tag - Child.vi->xml_Create Datatype.vi->xml_Create Signal.vi->xml_Create SignalList.vi->xml_Create Interface.vi->xml_Create InterfaceList.vi->xml_Create CLIPDeclaration.vi->XML_Generate XML.vi->CLIP XML Generator.vi
LabVIEW:  Attempted to call Create Element with empty name string.
Message 6 of 16
(17,089 Views)
Nevermind previous post (I guess you can't edit a message?), I figured this out. I wasnt selecting a datatype.
Message 7 of 16
(17,082 Views)
Very useful utility Christian!!
 Just a small suggestion to improve it. Now the CXG doesn't control if the VHDL data type is supported by LabVIEW. It could be a good improvement only display supported VHDL data type in the CXG "unassigned signals" list.
Message 8 of 16
(17,021 Views)
Hi, i already use this node, but i have some troubles, i used labview fpga, work good but in some applications with some level of complexity consumes a lot of resources and also i'm more famliar with vhdl code, for that reason I have many codes, i would like to use, and this node look a huge option for me, but i tried using this for a code for ps2 keyboard, i'm declare all, when i declare the frequecy of keyboard clock seems all good, when i going to the project and added the ip component element, appears a sign of warning in the icon of ip componet, when i check it, show me all the in and outputs but the clock no appears, can something tell me what is going on? please
Message 9 of 16
(16,887 Views)
Hi Emmanuelol -
This discussion thread is reserved for discussing bugs and features of the CXG utility. For help using the CLIP feature of LVFPGA itself, I recommend creating a new thread in the LV FPGA forum.
David Staab, CLA
Message 10 of 16
(16,871 Views)
