NI Home
Cart Cart | Help
You are here:
Reply
Active Participant
Christian_L
CLIP Node XML Generator (CXG)
[ Edited ]
Please provide feedback, comments, and questions on A XML File Generator for LabVIEW FPGA CLIP in this thread.
- David
(posted by Christian on behalf of David)
Christian Loew, CLA
Principal Systems Engineer, Embedded Systems
Please tip your answer providers with kudos.
Active Participant
zyl7
Re : CLIP Node XML Generator (CXG)
Hi !
I've got a small issue using  the CXG.
When setting Min and Max Clock value, sometimes the min value disappears when validating max value cliking outside the box.
Is that a bug or am I doing something wrong ?
View Cyril Gambini's profile on LinkedIn
Member
Ching-Yu
回應: CLIP Node XML Generator (CXG)
[ Edited ]
Hi Christian,
I already download CXG utility. However, I don't have vhdl code for test. Could you give me the the example you use (DemoClipAdder.vhd)?
I want to follow your steps in this article "XML Generation Utility for LabVIEW FPGA CLIP Nodes".
Ziva
Message Edited by Christian L on 02-18-2009 11:40 AM
Active Participant
Christian_L
Re: 回應: CLIP Node XML Generator (CXG)
 The ClipAdder.vhd file is included in the examples installed for FlexRIO in LabVIEW.
C:\Program Files\National Instruments\LabVIEW 8.6\examples\FlexRIO\FPGA Fundamentals\User CLIP\Adder
Christian Loew, CLA
Active Participant
David S.
Re: Re : CLIP Node XML Generator (CXG)
Hi zyl7 -
It may be a bug in the UI code. We are keeping a bug list, but I can't give any promises on when (or even whether) the utility will be updated for minor issue fixes.  This application has dual intent:  to automate CLIP XML generation for most users' needs, and also to show how a developer or company might design such a tool for their custom purposes.  You can treat it as a rubric for creating an automated XML generation utility of your own; my recommendation is to download the source and edit it to suit your needs appropriately.
David Staab, CLA
Staff Systems Engineer
Member
jakidd
Re: CLIP Node XML Generator (CXG)
I just download this and tried running the exe but always get this error after I add the port list and click on next:
Error -2677 occurred at Invoke Node in Simple XML.lvlib:Create Tag - Child.vi->xml_Create Datatype.vi->xml_Create Signal.vi->xml_Create SignalList.vi->xml_Create Interface.vi->xml_Create InterfaceList.vi->xml_Create CLIPDeclaration.vi->XML_Generate XML.vi->CLIP XML Generator.vi
LabVIEW:  Attempted to call Create Element with empty name string.
Member
jakidd
Nevermind previous post (I guess you can't edit a message?), I figured this out. I wasnt selecting a datatype.
Active Participant
sendia
Very useful utility Christian!!
 Just a small suggestion to improve it. Now the CXG doesn't control if the VHDL data type is supported by LabVIEW. It could be a good improvement only display supported VHDL data type in the CXG "unassigned signals" list.
Member
Emmanuelol
Hi, i already use this node, but i have some troubles, i used labview fpga, work good but in some applications with some level of complexity consumes a lot of resources and also i'm more famliar with vhdl code, for that reason I have many codes, i would like to use, and this node look a huge option for me, but i tried using this for a code for ps2 keyboard, i'm declare all, when i declare the frequecy of keyboard clock seems all good, when i going to the project and added the ip component element, appears a sign of warning in the icon of ip componet, when i check it, show me all the in and outputs but the clock no appears, can something tell me what is going on? please
Active Participant
David S.
Hi Emmanuelol -
This discussion thread is reserved for discussing bugs and features of the CXG utility. For help using the CLIP feature of LVFPGA itself, I recommend creating a new thread in the LV FPGA forum.
David Staab, CLA
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
