Components
A Localization Configuration Editor for LabVIEW
Is this when you are loading the xml file?  I'm still not sure at which step you are getting the error.  Also did this file work at one time?  What might have changed?  Maybe you could post the xml file.
Brian K.
Message 41 of 46
(4,839 Views)
Hi Brian,
    Thank you for concerning.  i added two controls into the old project. it fails when executing the funtion in capture.jpg when the label is the new control. The
Message 42 of 46
(4,833 Views)
Sorry, here is the xml file which I used. it seems .xml file could not be loaded so I changed extension to .txt
Message 43 of 46
(4,832 Views)
What is the VI that is generating the error?  Nothing is locked so you should be able to debug even further below.  Also error 1320 states "LabVIEW:  In run mode, LabVIEW cannot get or set a property for a control part that has not been created."  If you remove the controls you added does the problem go away?
Brian K.
Message 44 of 46
(4,816 Views)
Hi Brian,
   Yes, I did trace the function, it was actullay failed in the attached function. It could not go through any more.
  If I delete the new controls, the program works.
Message 45 of 46
(4,810 Views)
OK. Try this.
Brian K.
Message 46 of 46
(4,783 Views)
