07-02-2013 04:08 PM
I have win8 64 bit. Did you download the installer from http://zone.ni.com/devzone/cda/epd/p/id/6257?
07-03-2013 09:23 AM
07-04-2013 03:38 AM
I am able to open the source (Localization.lvproj), but ACM library files were renamed in new version so I had to relink all those VIs.
However I cannot open the LCE API.lvproj, because following VIs are missing (I cannot fined them).
07-06-2013 09:52 AM
Where can I get the missing "LCE" Vis?
07-08-2013 09:11 AM
Sorry, it was a national holiday in the US. I opened the source and noticed that the API VIs were missing like you said. Attached ar ethe missing files that come when you use the installer. I've also been making an updaed version that is hopefully simpler. It is in LV 2012 if you would like to try it out. I attached my beta in package below. It requires LV 2012 RTE
07-10-2013 01:53 PM
Thanks Brian!
I successfully installed the updated version. One bug that I discovered so far is that "Load from VI" doesn't do anything.
Could you also share the source code of the project? I would like to do some customizations of my own.
07-11-2013 09:35 AM
09-26-2013 01:44 PM
Question before I download and install LCE tools: Does this take a project and compile different executables into different languages? Or is it a single executable that the user selects desired language in run-time? Also does it allow developer to change language when running a VI in LabVIEW IDE, or does it have to be built into executable(s). Thank yoo. Larry
09-26-2013 01:53 PM
10-18-2013 08:41 AM
Hi Brian,
Your "Here you go..." two posts above post doesn't have any attachments. I'm very interested in your latest LCE updates.
I did download the LCE and NI Localization Library VI Package above, placed the LCE in the user.lib folder and installed the vi package. As mentioned above, the Load VI doesn't work. So I'm not quite sure on how to manually use LCE to create resources. Also, the example shows how to change the text in the string controls when language is changed, while I'm looking to change the Caption of controls and indicators. Will this be possible with LCE?
Rick
