Community Documents
Sync DSA, SC Express, and MultifunctionDAQ Card in One PXIe Chassis Using Channel Expansion
Overview
This code synchronizes DSA, SC Express, and a Multifunction DAQ cards in one PXIe chassis.  The DSA and SC Express card are synchronized using channel expansion, and the DAQ task is synchronized using Master/Slave synchronization.
Description
This example VI perfoms the following steps:
  1. The VI initializes a session to the DSA, SC Express and Multifunction DAQ Card.
  2. Then configures the different module, and puts the DSA and SC Express in the same task thus synchronizing their acquisitions.
  3. We set the DSA and SC Express task as the master task and export its sample clock to the Multifunction DAQ card in order to synchronize the acquisition with the DSA and SC Express cards.
  4. The VI starts the acquisition then reads the data and displays it on one graph.
  1. Download and open the example VI
  2. Configure the following settings for the DSA card:
    • Physical Channel
    • Minimum and Maximum Value
  3. Configure the following settings for the Multifunction DAQ card:
    • Physical Channel
  4. Configure the following for the SC Express card:
    • Physical Channels
    • Bridge Information
  5. Configure the Timing Parameters
  6. Run the VI
Requirements to Run
Software
LabVIEW 2011 or Later
Hardware
NI DSA and Multifunction DAQ Cards (hybrid compatible or PXIe Cards) and NI SC Express cards
Additional Images
Block Diagram
Contributors
