Community Documents
Darren's Nuggets
This page contains links to every Darren's Weekly Nugget and Darren's Occasional Nugget I have posted.
2014-08-14: Resizing objects with shift-drag (171)
2014-07-17: Pre-defined color maps for Intensity Graphs and Charts (170)
2014-05-13: Generate PDF files with a quick modification to the Report Generation Toolkit (169)
2014-03-25: Some common use cases for the VariantDataType VIs (168)
2014-01-30: Where is the LabVIEW INI file, anyway? (167)
2013-11-14: QuickBold! (166)
2013-11-07: Making While Loop subdiagram labels consistent between LabVIEW 2012 and LabVIEW 2013 (165)
2013-07-11: Wiring a DVR of a class to a property node (164)
2013-04-25: Custom VI Analyzer tests available on the VI Analyzer Enthusiasts community group (163)
2012-10-26: Adding custom content to the Create Project dialog (162)
2012-07-24: How to get the default value of any arbitrary data type (161)
2012-05-09: How to create an array of arrays (160)
2012-02-29: Easily find instances of property reads and writes on Class Property Nodes (159)
2012-02-27: INI token to enable logging during a VI Analyzer analysis session (158)
2012-01-26: Byte Offset from Point method on the String class to determine the displayed character at specified coordinates (157)
2010-11-15: Turn off Auto Grow for all structures in a folder of VIs (156)
2010-11-08: Cool LabVIEW 2010 Features Part XI: Export Data to Clipboard (or Excel or DIAdem) (155)
2010-11-02: Is Name Multiplatform VI (154)
2010-10-25: Quick Drop INI Tokens (153)
2010-10-18: Cool LabVIEW 2010 Features Part X: SubVI Inlining (152)
2010-10-11: Cool LabVIEW 2010 Features Part IX: Visible Display Style on Strings (151)
2010-10-04: Cool LabVIEW 2010 Features Part VIII:  Labels on Wires (150)
2010-09-27: Cool LabVIEW 2010 Features Part VII: View Cluster Constant as Icon (149)
2010-09-20: Cool LabVIEW 2010 Features Part VI: VI Analyzer Test Creator (148)
2010-09-13: Help us improve Edit > Create SubVI in LabVIEW 2011 (147)
2010-09-07: Cool LabVIEW 2010 Features Part V: Scripting (146)
2010-08-24: Cool LabVIEW 2010 Features Part IV: VI Server Rename with Quick Drop (145)
2010-08-17: Cool LabVIEW 2010 Features Part III: Built-in Merge Errors Function (144)
2010-08-09: Cool LabVIEW 2010 Features Part II: Fast Connector Pane Terminal Switching (143)
2010-08-02: Cool LabVIEW 2010 Features Part I: Replace and Insert with Quick Drop (142)
2010-07-26: Easily add your own code snippets to the palettes or Quick Drop (141)
2010-07-19: An easier approach to data member access with LabVIEW Classes (140)
2010-07-12: Accessing the original instance of a reentrant VI from a clone instance (139)
2010-07-07: Modifying the templates used to create new LabVIEW Class VIs (138)
2010-06-28: Always scroll to the latest data displayed in a string indicator (137)
2010-06-21: Several ways to speed up LabVIEW launch time (136)
2010-06-15: Palettes and .mnu files (135)
2010-06-07: Functions that execute even with an incoming error (134)
2010-06-01: Improving drag response speed in the Navigation Window (133)
2010-05-24: Using the Format Into String function to turn an enum value into a string (132)
2010-05-17: Various items that LabVIEW stores in the LabVIEW Data folder (131)
2010-05-10: Specifying multiple lines of multiple patterns in a LabVIEW file dialog (130)
2010-05-03: Shipping and Customized Icon Editors (129)
2010-04-26: The Convert Unit function (128)
2010-04-19: Keyboard shortcuts for adding and duplicating case structure frames (127)
2010-04-12: Toggling a checkbox by clicking its Boolean Text (126)
2010-04-05: Creating a "Help > About..." dialog for a built application (125)
2010-03-29: Sorting tree control items (124)
2010-03-22: The redesigned Edit Events dialog in LabVIEW 2009 (123)
2010-03-16: Searching the VI Hierarchy Window in LabVIEW 2009 (122)
2010-03-08: Using the Heap Peek window to identify and correct insane objects (121)
2010-03-01: The subroutine priority setting on VIs (120)
2010-02-22: An important performance tip related to automatic error handling (119)
2010-02-15: Programmatically build EXE, DLL, and Source Dist build specs with the App Builder API (118)
2010-02-08: A nice set of 16x16 glyphs that ships with LabVIEW for use with listboxes, multicolumn listboxes, and tree controls (117)
2010-02-01: Easily bold particular sections within a user-visible string (116)
2010-01-25: Avoid using Type Cast with references of different data types (115)
2010-01-18: Excluding certain parts of your diagram from block diagram cleanup (114)
2010-01-11: The Palette API (113)
2010-01-04: Darren's thoughts on VI recursion (112)
2009-12-28: Retain Wire Values (111)
2009-12-21: Using node labels as comments with diagram cleanup (110)
2009-12-14: Norm's Tree Control API (109)
2009-12-07: Commenting your VIs with images (108)
2009-11-30: Identifying performance bottlenecks with the VI Profiler (107)
2009-11-23: Place VI Contents VIs on the palettes (106)
2009-11-16: A suite of modern-looking front panel controls (105)
2009-11-09: New RUN_TIME_ENGINE conditional disable symbol in LabVIEW 2009 (104)
2009-11-02: Using design patterns to speed up development and reduce code maintenance (103)
2009-10-26: Using the Matrix Size function to determine the size of any 2D array (102)
2009-10-19: All about removing VI block diagrams (101)
2009-10-12: Copying LabVIEW preferences settings between LabVIEW versions (100)
2009-10-05: Using the VariantDataType VIs to parse LabVIEW data types (99)
2009-09-21: Customizing the "Send To" menu to open a VI with  a specific installed LabVIEW version (98)
2009-09-14: Ctrl-Shift-E to find the current VI in the project window in LabVIEW 2009 (97)
2009-09-09: Run the VI Analyzer directly on project items with the VI Analyzer Toolkit 2009 (96)
2009-08-31: Tools > Options settings that make my life easier (95)
2009-08-24: Disabled property on the Control class is an Enum in LabVIEW 2009 (94)
2009-08-17: Diagram cleanup enhancements in LabVIEW 2009 (93)
2009-08-10: Watch out for nested Parallel For Loops (92)
2009-08-03: Creating your own pull-down menu options (91)
2009-07-27: Cool stuff in the right-click menu of front panel scrollbars (90)
2009-07-20: How to efficiently add items to the beginning of a 1D array (89)
2009-07-13: The LabVIEW Known Issues webpage (88)
2009-07-06: Searching the LabVIEW Help online (87)
2009-06-29: When to use Controls, Type Defs, and Strict Type Defs (86)
2009-06-22: Getting rid of the toolbar flicker when closing a LabVIEW built EXE (85)
2009-06-15: Linked Tunnels in multi-frame structures (84)
2009-06-08: "Update Value while Typing" option on string controls (83)
2009-06-01: Use the new LabVIEW Idea Exchange for submitting LabVIEW feature requests (82)
2009-05-26: Easily relink all subVI instances at once (81)
2009-05-18: Adding a Tools > Explore option for locating VIs on disk (80)
2009-05-11: Quickly change the data type of a numeric constant (79)
2009-05-04: Editing properties of multiple front panel or block diagram objects (78)
2009-04-27: Implementing an auto-complete string on the front panel (77)
2009-04-20: Grouping and locking front panel objects (76)
2009-04-13: Assigning tags to VIs or objects within VIs (75)
2009-04-06: Auto populating folders in the LabVIEW Project Window (74)
2009-03-30: Dealing with the <Not A Path> value in path data types (73)
2009-03-23: Case Structures part 5 - Case structure miscellany (72)
2009-03-16: Case Structures part 4 - Enum cases (71)
2009-03-09: Case Structures part 3 - String cases (70)
2009-03-02: Case Structures part 2 - Numeric cases (69)
2009-02-23: Case Structures part 1 - Boolean and Error cases (68)
2009-02-16: Sorting arrays of clusters (67)
2009-02-09: My tips on preparing for the CLAD, the CLD, and the CLA (66)
2009-02-02: Easily determining whether or not to show scrollbars on a Tree Control (65)
2009-01-26: Inserting objects on wires in a certain way (64)
2009-01-19: Darren's favorite LabVIEW features over the years (63)
2008-10-14: Advanced tips for using Quick Drop in LabVIEW 8.6 (62)
2008-08-14: Smaller VI file sizes in LabVIEW 8.6 (61)
2008-08-11: Aborting modal VIs without killing LabVIEW (60)
2008-03-20: Opening subVI front panels from the palettes (59)
2007-09-21: Connector Pane terminals default to Required in LabVIEW 8.5 (58)
2007-08-15: Three new performance-enhancing features in LabVIEW 8.5 (57)
2007-05-18: Easily debug event firing order of Event Structures (56)
2007-05-14: A VI Analyzer test for detecting potentially troublesome Event Registration Refnum wires (55)
2007-02-14: Making Quick Launch tests for the VI Analyzer (54)
2007-01-16: Keep it simple (53)
2007-01-08: LabVIEW 8.2 Upgrade Issues webpage (52)
2007-01-02: Customizing the appearance of Numeric controls with advanced formatting (51)
2006-12-28: Dealing with File Shortcuts and the File I/O functions (50)
2006-12-18: Keyboard shortcuts in the Color Picker (49)
2006-12-11: Using the maximum number of Undo steps in LabVIEW (48)
2006-12-04: Using the Class Browser in LabVIEW (47)
2006-11-27: Using XControls to give new life to custom probes (46)
2006-11-20: Common hard-to-find menus and options in LabVIEW (45)
2006-11-13: Easily viewing a VI's call chain at runtime (44)
2006-11-06: An explanation of the "Synchronous Display" feature (43)
2006-10-30: Picture Control tips (42)
2006-10-23: History Probes (41)
2006-10-16: Error handling tips (40)
2006-10-09: Faster data lookups with Variant Attributes (39)
2006-10-02: LabVIEW birthday wishes from me (38)
2006-09-25: Read from Spreadsheet File.vi and Write to Spreadsheet File.vi are polymorphic in LabVIEW 8.2 (37)
2006-09-18: See most recently used folders in the Places Bar in LabVIEW file dialogs (Windows only) (36)
2006-09-11: A couple of cool LabVIEW 8.2 INI tokens (35)
2006-09-05: Display the path to LabVIEW.exe in your VIs' title bars (helpful when running multiple LabVIEWs) (34)
2006-08-28: In Range and Coerce does something useful with paths in LabVIEW 8.2 and later (33)
2006-08-21: Six new VIs on the File I/O > Advanced File Functions subpalette (32)
2006-08-14: Show Hidden Controls and Indicators feature in LabVIEW 8.20 (31)
2006-08-08: Remove Breakpoints from Hierarchy feature in LabVIEW 8.20 (30)
2006-07-31: Moving text around in the Icon Editor with the arrow keys as you type (29)
2006-07-24: Adding items to a ring/enum with Shift-Enter (28)
2006-07-17: "Case Insensitive Match" option on a Case Structure with a String input to its selector (27)
2006-07-10: The Implies function often makes Boolean logic easier to implement and understand (26)
2006-07-03: Just *try* the Auto Tool (25)
2006-06-26: An easy-to-use Progress Bar VI for your For Loops (24)
2006-06-19: The "Call Setup..." feature on subVIs in LabVIEW 8.0 (23)
2006-06-12: Interesting data flow behavior of Flat Sequence Structures (22)
2006-06-05: Space Constant on the String palette in LabVIEW 8.0 (21)
2006-05-30: Pressing Ctrl-Enter in a string constant toggles the scrollbar on the constant (20)
2006-05-22: Defer Panel Updates to speed up UI updating (19)
2006-05-15: A 100% G-based MD5 VI that ships with LabVIEW (18)
2006-05-08: Ctrl+A now selects all objects (17)
2006-05-01: Use Ctrl+tab to cycle through the open LV windows (16)
2006-04-24: Dragging an image file into the icon area creates icons for the VI based on that image (15)
2006-04-17: How to set transparency for front panels (14)
2006-04-10: Format Into String inputs in arbitrary order (13)
2006-04-03: A recursive file listing VI that ships with LabVIEW (12)
2006-03-27: Press shift when dragging a control or expanding a structure to make the display scroll faster (11)
2006-03-20: Quickly sample a color while using the paintbrush tool (10)
2006-03-13: Switch the inputs on 2 input primitives by holding ctrl and hovering over the function (9)
2006-03-06: (1) Quickly starting with a blank square icon for a VI and (2) 4x2x2x4 default connector pane in LabVIEW 8.0 (8)
2006-02-27: Dragging controls into control references to assign their type (7)
2006-02-20: Ctrl-scroll wheel to scroll the frames of multi-frame structures (6)
2006-02-13: Features that help with navigating front panel arrays (5)
2006-02-06: Using the Select function instead of Merge Errors.vi to improve performance (4)
2006-01-30: Multiple options for the path input to Open VI Reference (3)
2006-01-23: (1) Empty Array? function and (2) Multiple uses for Empty String/Path? function (2)
2006-01-16: (1) Search/Split String speed boost and (2) Ctrl-double click a subVI (1)
Darren Nattinger, CLA
LabVIEW Artisan and Nugget Penman
Contributors
