Multisim and Ultiboard
single sided pcb
Hi all
First time poster.
Noob type question coming up.
How do i get Ultiboard to autoroute as a single sided pcb? Unless i've got it completely wrong you can only have a minimum of a top and bottom copper layer i.e. a two-sided board. I'm going to make my own pcb's and don't want to use double sided.
Is it as simple as telling it not to use via's of any description or is that a bit of a sledgehammer method?
Also, does anyone know of any software that will take the schematic from multisim and autoroute a veroboard/stripboard layout?
Thanks in advance.
Karl.
Message 1 of 9
(10,351 Views)
Accepted by PCBNoob
You can mark the bottom layer as unroutable.
  1. Click Options > PCB Properties.
  2. Select the Copper Layers tab
  3. In the Allow Routing box, select Copper Bottom, then click Properties
  4. Uncheck the Routable check box
If you have a version that has PCB Layers in the spreadsheet, you can also do this a little easier.
  1. Select the PCB Layers tab in the Spreadsheet View
  2. For Copper Bottom, change Routable to No
Garret
Senior Software Developer
Circuit Design Community and Blog
If someone helped you, let them know. Mark as solved or give a kudo. 🙂
Message 2 of 9
(10,348 Views)
Excellent. Thank you.
I knew i must have missed something obvious.
Many thanks.
Karl.
Message 3 of 9
(10,343 Views)
HI, Have a nice day.
I having some question.
1. Where do i can find the normal 2 pins IR reciever, I might that is in phototansistor, but i can't found it inside the transistor and diode part of multisim.
2. How to allow a single sided board with copper at the bottom , and i place the components in the non-copper side?
3. Normal double sided copper board with placing components in one side only?
 I am new to this program. Please help me. Thanks a lot. Hopefully you can give me a helping hand .
TQ
jac_wah@hotmail.com
Message 4 of 9
(9,110 Views)
hi garret
i see you are the best with this soft
i need to change the tickness of connections line,can you suggest me how?
Message 5 of 9
(5,953 Views)
how can i change the tickness for connection lines?
Message 6 of 9
(5,952 Views)
 I just have Multisim 10 german edition but I think the procedure has not changed too much.
First you have to check the "select copper trace" button.
Then mark the trace you want to change. Normally only a part of the track will be highlighted. Go to the "select complete track" menue and check it, now the complete track should be highlighted.
Go to the "properties" menu, and check "general". You will find a field indicating actual thickness (or width) of the track. (You can pre-set standard width for each net, so sometimes there appears "standard".) With the pull-down arrow you can select standard width, or enter your own value.
All this refers to width of a track, i.e. horizontal dimension.
Thickness usually refers to the vertical dimension of the copper layer. The thickness of the copper layer is determined by the manufacturing process and cannot be changed via Ultiboard (usually 35 um thickness). Also, it is difficult to manufacture tracks of different thickness (vertically) on the same board.
Message 7 of 9
(5,831 Views)
Usually the bottom side of a board is the copper side, and components are placed on the opposite (top) side of the board. So no problems as long as you use this combination.
Of course it depends on what you want to build which side is regarded as top or bottom, but of course you can use the standard configuration and simply turn the ready board around if you need components on bottom side and copper on top side.
If you wand components and copper tracks on same side you can select the "copper top" layer as active layer and use the standard placement of components. But this will cause problems when soldering since pads will not be accessible for many parts once they are placed. In this case, you have to manufacture the board as double sided but use only one layer for copper tracks. All pads will automatically appear on both sides and are accessible for soldering.
Message 8 of 9
(5,829 Views)
That does not work for me. Track is still on component side of the board. Maybe because Through board via from Copper Top to Copper Bottom cannot be Unchecked.
Message 9 of 9
(5,299 Views)
