10-04-2009 08:24 AM
There are several AC voltage sources model in Multisim, however none of them allow me to change the ac phase inside a simulation.
The simplest way would be to modify the AC voltage source and add an input for the phase value, but I do not know how to do it.
I am using Multisim 10.1
Best regards
Michel
10-06-2009 02:05 PM
Hi Michel,
Most AC sources, such as the AC_VOLTAGE source, have more than one phase field; for example, you will often see both a 'Phase' and an 'AC Analysis Phase'. The 'Phase' field will affect the simulation when running a transient analysis, and the 'AC Analysis Phase' only affects the simulation under an AC analysis. I would check to make sure that you're using the correct fields.
If you're still having trouble, feel free to post a circuit and we can investigate this further.
