Multisim and Ultiboard
problem assembling this cicuit on multisim
 hi i am new to multisim and this forum
i was trying to assemble the following cirsuit of wireless switch im multisim but got stuck in the relay part how do i select the right relay as in the circuit diagram,,,,and also how do i make the load connectionsckt.JPG please help ASAP ,,,the L and N connections also are confusing
(7,179 Views)
Can you please tell me what part do you find confusing in the L and N connections?
As per the circuit diagram you can connect an AC source to it with 230V and 50Hz
For relay use RELAY1C_VIRTUAL component.
It is same as the relay in the circuit diagram.
Hope this helps.
Ujjval
(7,143 Views)
To add to that, L and N stands for Live and Neutral respectively. Be sure to research your country's electrical code before connecting circuits to the mains.
Message Edited by yyao on 10-01-2009 08:45 AM
Yi
Software Developer
National Instruments - Electronics Workbench Group
(7,138 Views)
I have use pnp transistor as switch circuit with IR remote signal but output at collector is 0.3v Are the 5v dc relay operate from this voltage
(4,170 Views)
can I ask which port on that relay is the comon, NO and NC? sorry. new to this application
(3,121 Views)
