08-13-2009 02:26 PM
Error during autorouter preprocessing.
Source: Autorouter
Invalid Polygon Data
This is the error I'm getting. What is a polygon data? There is no listing for it in "HELP" (JOKE THAT IT IS)
I had an 8 layer board done, except for test points that also cannot be added. I found an error in the schematic. After saving the board, and changing the schematic in Multisim, I transferred it back to Ultiboard. Now I cannot autoroute it.
Any help would be appreciated.
Scotty544
Solved! Go to Solution.
08-14-2009 08:53 AM
Hi Scotty,
This error is likely caused by a component on your board and you have to isolate that component, to find that component this is what I do:
1. Remove half the components on your board
2. Resave the file with a new name
3. Start the router and see if the error still exists
4. If yes, again remove half the components on the board and reroute. If the router starts, you know something you deleted is caused so open the original file and delete the other half instead.
5. Continues this process until you can isolate the problem component
Once you find the problem component, the next step is to find what part of the component is cuasing the problem. If you are use the Power Pro edition, click on the component and select Edit>>In Place editor, usually, it's the pads that are causing the problem. Delete the pads and replace them. If you don't the the "In place editor" option, you have to modify this component in the footprint editor.
If you are not able to fix the problem, create a service request at NI Support and send us your file.
08-15-2009 09:18 AM
Hi Scotty,
I'm glad to see you were able to solve the problem. If you still have the original file with the problem (or a file that has isolated the problem), I would appreciate if you could post that file here. I could then take a look at the file to see if I can make this error more descriptive (or even prevent it from causing a problem at all) in a future release.
08-17-2009 06:14 AM
Garret,
Tien Pham found my problem. It was a small piece of silkscreen on the bottom layer. It was probably left over from trying to flip a SMD test point to the bottom from the top layer. I may not have had the silkscreen layer turned ON but deleted the test point from the top. In other words, the silkscreen changed layers, but the pads did not. He also has a copy of the file.
Thanks for the help.
Scotty544
