02-17-2015 10:37 AM
Hi All,
I am simulating a circuit containing the photodiode BPW 34 in Multisim. This elements has 3 pins. The two usual one for diodes and a third one named "Input (P)". I assume that this pin is meant to input light signals from an external light source to simulate the reaction of the photodiode:
1) am I right?
2) Which source can I use to produce light output that can be sent to the photodiode input pin?
Cheers,
Khaled
03-06-2015 03:10 PM
Hi Khaled,
Multisim does not understand light, so what you have to do is use voltage/current source to represent light or other real world properties. For example you can use a voltage control switch and connect it to a diode as shown in the attached file.
