12-04-2007 03:47 AM
12-04-2007 07:31 PM
The reason your getting this message is because you have you maximum timestep in the simulator settings is way too low. Try setting it to .0001.
Also, you need to ground the second timer.
There is one other problem and that is with the first timer. This has no bearing on the error message, but you have the duty cycle of the first timer set below 50% and in it's current configuration would not work in reality. Your R9 should alway be lower in value than your R10. The way to achieve less than 50% with a timer is to place a diode across R10 and recalcualte your resistor values.
I mhope this helps. Let me Know if you encounter any other errors.
12-19-2007 01:16 AM
12-29-2007 11:11 PM
12-30-2007 09:14 AM
O.K. I am going to tackle these as I get a solution for you or an explaination compiled.
1. I did manage to get the circuit simulating for the full time without convergence error. What I did was to take all the Analog components off of VCC and run them to the analog DC Power. I have found on a number of occassions that it is best to separate the analog components from the digital power sources and run them to their own DC Power Source to prevent problems when simulating. For some reason when you hook analog and digital components together on the schematic the simulator likes for each to be coupled to its appropriate power source otherwise it starts coughing up errors. As far as real time is concerned that is not possible with Multisim. You can get close, but you run the risk of timestep too small errors. It takes the simulator time to number crunch and it can't do that very fast. The larger the circuit the more real time it takes to simulate. On very large circuits it may take 1 minute of "real time" to simulate 1 second of circuit time. Basically it is the nature of the beast and there are very limitied options available to speed it up without it spitting errors at you. I will post the updated circuit for you to try.
2. DRC errors do not effect simulation. They are user adjustable and only there to advise you that, according to your settings, you have a wire connected where you didn't want it connected i.e DC voltage on a timer output. You can turn these on or off by going to TOOLS>ELECTRICAL RULES CHECK>ERC RULES and disbling the ones you want by turning them from red to green by clicking on the square.
12-30-2007 09:39 AM
3. The transfer error was caused by their being 2 instances of Refdes U2 in the circuit. How this happened I do not know, but you need to change the 7404 designation from U2 e to another number and then it will transfer properly.
4. I am not exactly sure what your requestring here, but it sounds to me like everyhting is routing on the top layer. This can be dealt with in two ways. One way is to lock the PCB setting within Multisim. This only works if you have the full spread sheet at the bottom avaialble to you. Goto the Nets tab and scroll tio the right until you see LOCK PCB SETTINGS. click on it to highlight all nets and then select one net and change it from yes to no and it will change all of them at the same time. The other way is to do the same procedure in Ultiboard. Goto Nets>Routing layers and select all the nets by using CTRL>Left mouse button and then change just one of them to change them all. This second method will also allow you to change just certain parts to be routed on certain layers. You have to change the numbers to reflect which side to route them on. 10=Top 01=Bottom 11=Both sides. This technique works with the Power Pro Edition with the full spreadsheet. If your version is different then the only technique I know of that can get you routes where you want them is to edit them in the Net List Editor within Ultiboard
12-30-2007 10:11 AM
12-30-2007 11:31 PM
12-30-2007 11:37 PM
12-30-2007 11:44 PM
