06-22-2015 01:07 AM
Hi all
My circuit simulation working perfectly on the simulation. But in the real world, it would destroy the input signal and also output completely noise with distortion (input is 1 MHz sine wave, gain is about 40)
I soldering on the PCB and double check the soldering point
Sorry for my bad English
06-22-2015 01:39 PM
The TI data sheet for the LMH6559 shows a capacitor between R8 and R11. Without that capacitor the DC bias may not be correct.
Lynn
06-22-2015 03:25 PM
thank you for your kind reply
eventhough if it is not having a buffer. reselt is same as before.
I canot understand the situation
plase help me
06-22-2015 05:07 PM
Hi, could you explain to me a little bit more of what is it specifically that you are trying to do? Maybe we can work on finding a workaround for it.
06-22-2015 08:36 PM - edited 06-22-2015 08:45 PM
I am try to make a ammplifire with buffer to drive coaxial cabale.
input is connected to the 50 ohm antena and output is connected to the DAQ card
Gain=50-40
I made anothe circuit it also work perfectly on the simulation but not in the real situation. (in put is almost destroted and out put is large noise)
06-24-2015 04:59 AM
have you got a screenshot of your layout?
Is the 50 Ohm resistor necessary after each opamp? I guess not...
06-24-2015 01:11 PM
Thank you very much for your kind reply
so that, i am expected to compensate the impedance of the opamp, othe wise for low freqency lot of DC voltage create floting the signal.may be i am wrong
