08-19-2015 08:43 PM
Solved! Go to Solution.
08-20-2015 09:55 AM
I recreated your circuit and was able to run Fourier analysis with no issue. What version of Multisim are you using? Are you running Fourier analysis with default settings?
Could you attach your circuit so we can take a closer look?
Jeff
08-22-2015 08:55 AM
I am using multisim version 11.0 and I tried to simulate the circuit by setting the parameters to default.but still i face the same problem.
08-24-2015 09:12 AM
Hi Priyatham24,
Could you attach your ms11 file so we can take a closer look?
Jeff
08-24-2015 10:49 AM
I am attaching ms 11 file here.but can you be quick in analysing the simulation, because i have got some deadlines, so i request you to make it quick. thanking you in advance.
08-24-2015 11:14 AM
This was caused by an legacy issue with our internal simulation engine with the syntax used in some device parameters - in this case the square brackets used in the current expression in your output variable.
This was fixed and works correctly in Multisim 13 and later versions.
If Multisim 13 is not an option for you, you can get the analysis to work in Multisim 11 by removing the current output variable in the Output tab of the Fourier Analysis settings, selecting "All variables" from the dropdown in the left-hand variables list, and adding the "I(h1:xcp1)" variable to the analysis. This is the same variable, just with a different syntax, and will not cause any issues when running the simulation.
I hope that helps.
Jeff
08-24-2015 12:19 PM
08-31-2015 08:50 PM
why dont someone help me regarding using smps in multisim. I have already posted in the forum regarding this but none replied.can you help me regarding this.for more, check my post on smps with flyback as subject
