Multisim and Ultiboard
multisim
I tryied to simulate this circuit, but I get always an error. Can you help me ?
(4,536 Views)
Hi Linus,
what kind of error are you experinencing?
In the following I post some interesting Multisim tutorials:
Multisim/Ultiboard Case Study Tutorial: Design and Implementation of myDAQ Compatible PCB
Transitioning from PSPICE to NI Multisim: A Tutorial
Practical Teaching Ideas with NI Multisim
I hope these will help you.
Kind Regards.
Cla_CUP
(4,517 Views)
Thanks for your answer.
The error I get is the following message
"Simulation error"
"A simulation  error has occured. Would like to run the Convergence Assistant to attempt to resolve this problem automatically?"
When I answer YES is popping up a windows with "Attempting to resolve convergence issue"
Then a bar green appear and it seems is trying to resolve the error with several steps, but after completed is always written Simulation error still occurs, and that's doesn't help me to understand what is wrong....
Final message is "Failed to resolve convergence issue"
I think it should be better to have a indication of what is wrong instead to try to resolve the "convergence issue".....
I get the same error also if I connect a LED with a battery of 12V and a switch in series, with a resistor to big or to small....for example 10K or 1 Ohm. With a 1K resistor, it works ......
Very arcane behavior...
Linus58
(4,505 Views)
