Multisim and Ultiboard
multisim
Hi, i am  a student using multisim 13 and the course sylabus requries the simulation and testing of a MAX7400 switch capacitor filter IC. This chip is available on older versions of mulisim as some of my classmates have it in the master database.
Is there a place that i could download the component from a library?
(4,132 Views)
I am also running Multisim 13.0 and have found the MAX7400_DIP8 by navigating to Place >> Component then searching for MAX7400 under the Master Database.  There is no way to download this individual component which should be shipped as standard, it may have originated from a bad install of Multisim.
Or it may be that you have a different version (Student/Pro) to your colleagues so this would be worth checking (navigate to Help >> About Multisim to find your version)
Kind regards,
James V.
NI UK Applications Engineer
(4,092 Views)
