Hi all,
I want to design Hysteresis current control technique in Multisim. For that design I require a component named relay which I didn’t find in Multisim.
In Labview relay is there. The parameters of that relay are as follows:
Switch on point:
Switch off point:
Output when on:
Output when off:
In multisim also some relay components are present but I didn’t find any relay with above mentioned parameters. So I request all to suggest me a component in multisim with above mentioned parameters.
Because of this problem I tried hysteresis control with COMPHYS block which is available in Multisim, bit I didn’t get the exact result. I am attaching the circuit which I have been trying. Please verify the circuit and help me in getting the result.
Thanks in advance.
