09-27-2014 02:51 AM
when i try to build some projects by IC 74LS95 i observed that that IC not present in Multisim 11 and also in multisim 13
plzzz add this TTL IC ...
plZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
10-28-2014 09:23 AM
Hi there,
You are correct, this part is not in the Multisim Master Database. I was looking around and found out that some manufacturers have marked this part as obsolete.
The 74195N is also a 4-bit Parallel Access Shift Register.
Best,
10-28-2014 09:42 AM
You should not use components which may be discontinued by the manufacturer(s) in the near future. Unfortunately parts are discontinued more and more faster. Most manufacturers have recommendations for replacing discontinued components with ones with same or better functionality.
