07-02-2007 11:02 AM
07-02-2007 01:06 PM
07-03-2007 09:32 AM
07-05-2007 11:30 AM
Thank you for your time, Maxish.
I think I've got some model specification errors,which are as followed:
Warning:
Simulation was not initialized properly. Please restart.
Instrument operation performed (2007, July 05, Thursday, 23:42:53)
| Instrument Analysis: Transient Analysis
| | Plot title:
| | Analysis settings
| | | Initial Conditions: Automatically generate initial conditions
| | | Starting time (TSTART): 0
| | | Stop time (TSTOP): 1e+030
| | | Plotting increment (TSTEP): automatically calculated (less than: 1e+030)
| | | Maximum time step (TMAX): automatically calculated (less than: 1e+030)
| | Perform consistency check
| | Variables from analysis
| | | Show device values at the end of the simulation
| | Representation as SPICE commands
| | | begin-scope page
| | | checknodes 3
| | | save all
| | | iplot all
| | | set trtol = 7
| | | set itl4 = 100
| | | set convlimit
| | | set rshunt = 1e+012
| | | -param hrange 0 1e+030
| | | save
| | | tran -env-options 1e-005 1e+030 0 1e-005 auto_ic auto_tstep auto_tmax
| | | if-error end-scope audit-log-show
| | | show all
| | | showmod all
| | | end-scope
| | Multisim Default Analysis Options
| | | Truncation error overestimation factor: 7
| | | Upper transient iteration limit: 100
| | | Enable convergence assistance for code models
| | | Shunt resistance from analog nodes to ground: 1e+012
| Output from instrument analysis
| | Unable to setup analysis
| | doAnalyses: parameter value out of range or the wrong type
| | tran simulation(s) aborted
| | ASRC: Arbitrary Source
| | device be_md3_dlyh be1:x_md3_d be1:x_md3_d be_md3_abm2 be1:x_md4_u be_md4_uvbs
// I delete some of these at here.
| | Capacitor: Fixed capacitor
| | device c1:x_md3_dl c1:x_md3_dl c_md3_dlyhs c_md3_c2:xu c_md3_c1:xu c_md4_inv6_
| | model C C C C C C
| | capacitance 1e-011 1e-011 1e-008 1e-011 1e-011 1e-012
| | Vsource: Independent voltage source
| | device v_md4_inv2_ v_md4_rs_v1 v_md4_inv3_ v_md5_nand_ v_md2_nor3b v_md2_nor3a
| | dc 5 5 5 5 5 5
| | acmag 0 0 0 0 0 0
| | device v_md2_rs2_v v_md2_rs1_v v_md2_inv2_ v_md2_inv1_
| | dc 5 5 5 5
| | acmag 0 0 0 0
| | Capacitor models (Fixed capacitor)
| | model C
| | cj 0
| | cjsw 0
| | defw 0
| | narrow 0
| | tc1 0
| | tc2 0
| | vc1 0
| | vc2 0
| | cmult 0
| | t_measured -273
| | t_abs -273
| | t_rel_global -273
| | t_rel_local -273
| | Switch models (Ideal voltage controlled switch)
| | model _md3_dlyhs_ _md3_dlyhs_ _md3_dlyhs_ _md3_dlyhs_ _md3_dlyhs_ _md3_dlyhs_
| | model _md2_inv2_p _md2_inv1_n _md2_inv1_p _md1_trig2_ _md1_trig1_ _md1_trig3_
07-05-2007 11:50 AM
In my opinion, there must be something different beteen Barkeley SPICE and PSPICE,that leads the errors.Unfortunately,I have not found it out.
Thank you for any response in advance!
07-05-2007 01:26 PM
07-13-2007 11:06 AM
04-30-2009 08:53 AM
Hi, I'm also trying to simulate the IR2110 using multisim ver 8. I'm using the pspice model downloaded from IR IC simulation page.
http://www.irf.com/product-info/models/sim/index.html
When I run the simulation the following error shows up:
Error: unknown subckt: on line 14:xu1 $13 $u1_open_nc2 $u1_open_nc3 $u1_open_nc $vcc $11 $12 $5 $vcc $0 $0 $6 $0 $7 ir2112__ir2112__2
Error: unknown subckt: on line 36:xu2 $2 $u2_open_nc2 $u2_open_nc3 $u2_open_nc $vcc $1 $4 $3 $vcc $0 $0 $7 $0 $6 ir2112__ir2112__2
Error on line 14 in C:\DOCUME~1\PATPHY~1.000\LOCALS~1\TEMP\02.CIR.cir: xu1 $13 $u1_open_nc2 $u1_open_nc3 $u1_open_nc $vcc $11 $12 $5 $vcc $0 $0 $6 $0 $7 ir2112__ir2112__2
unknown device type - error
Error on line 36 in C:\DOCUME~1\PATPHY~1.000\LOCALS~1\TEMP\02.CIR.cir: xu2 $2 $u2_open_nc2 $u2_open_nc3 $u2_open_nc $vcc $1 $4 $3 $vcc $0 $0 $7 $0 $6 ir2112__ir2112__2
Any ideas ???
Pat.
09-21-2014 09:56 AM
