06-10-2009 06:45 PM
Part Number Pinout is Pinout should be
J201 SGD DSG
VN0300L DGS SGD
2N3904 CBE EBC
PN2222A CBE EBC
MPSA13 CBE EBC
PN2907 CBE EBC
2N3906 CBE EBC
06-11-2009 01:03 PM
Hi there,
Thank you for reporting this. It looks like J201 and J202 have incorrect pinouts. We will fix this as soon as we can.
However, the remainder of the parts that you listed are correct, although at first glance, they may not appear to be. The pinouts specified in the Edit Footprint dialog are mapped using the to the Ultiboard pinout information prior to being imported through Ultiboard. It just so happens that the Ultiboard pinout for the TO-92 package is set up to reverse the pin order that you have listed. This may seem convoluted, but this is done to maintain compatibility with other CAD packages. To view the Ultiboard pinout information, you can do this:
Hope that helps.
06-11-2009 01:18 PM
06-11-2009 01:39 PM
06-19-2009 03:19 PM
Hi jg_fs,
Your feedback and insight to this problem is very important to us. The issue of footprint pin ordering in our database has been around for a long time and is a tricky one to reconcile. We try our best to make Multisim easy to use while providing compatibility with other layout tools. Part of this confusion arises from how Multisim handles pin ordering to maintain compatibility with other layout tools. We spend a significant amount of effort correcting, improving and adding new components and footprints. We do our best to insure that the end result is a board which can be manufactured and behave correctly. Although the pin order appear confusing, the end result should be correct. However, we strongly recommend all design engineers to recheck their Gerbers prior to manufacturing as you have done.
Another part of this issue arises from the fact that semiconductor vendors cannot agree on pinouts. For example, compare the following datasheets on the 2N3904:
You will see that the pin numbering differs between vendors and some prefer not to number them at all! Either way, any pin ordering that we choose would be disagree with one vendor or another. To make matters worse, it seems that JEDEC only specifies mechanical dimensions but has no input about the pin numbering of transistor outlines and there is no clear industry standard.
Currently, we are thinking of methods of eliminating this multiple pin ordering confusion. One idea we have is to create vendor specific footprints, one footprint per vendor and eliminate the need for custom pin order remapping. This way, when you place a component, you are guaranteed that the footprint mapping table matches what you find in the datasheet. If you have suggestions or other ideas, we would love to hear about them and take them into consideration for our future work.
Thank you.
