I am developing a pre amp circuit for my experiment. I am thinking of using clare LCA110s single pole optomos relay in it. Before actually moving to circuit design I was simulating the design on multisim 10. I am unable to find the component.....any suggestions?
This component is not in our database but there are behavior relay models in our database that you can try. Select Place>>Component, select 'Basic Virtual' family from the "basic" group and you should find a few relay models. If this is not what you are looking for, you try using the virtual MOS to create the relay circuit base on the datasheet.
