Multisim and Ultiboard
is label field searchable in MS ?
Hello everybody.
I 'd like to know , is the component's LABEL field  searchable?
to me it looks like it is not.
it seems to me the MS does "Search  all elements for the entered string", according to it's help, but  does not do it for the LABELs of components.
is it default behavior?
can it be changed?
MS 13.0
W7
Desktop PC
thanks
Michael
(4,523 Views)
Hi Michael,
If you select Place>>Component>>Search, the fields show what you can search, unfortunately, label is not an option. I am assuming you are referring to the Label field when you double the part then select the "Label" tab.
Tien P.
(4,455 Views)
Hello Tien, thanks for response.
you are right, the label can be changed by using double click on  the part then select the "Label" tab.
I think it would be a beneficial to have the Label field searchable.
please pass it to your developing team.
thanks
Michael
(4,436 Views)
