11-22-2014 07:16 PM
Hello everybody.
I 'd like to know , is the component's LABEL field searchable?
to me it looks like it is not.
it seems to me the MS does "Search all elements for the entered string", according to it's help, but does not do it for the LABELs of components.
is it default behavior?
can it be changed?
MS 13.0
W7
Desktop PC
thanks
Michael
11-28-2014 08:35 AM
Hi Michael,
If you select Place>>Component>>Search, the fields show what you can search, unfortunately, label is not an option. I am assuming you are referring to the Label field when you double the part then select the "Label" tab.
11-29-2014 09:56 AM
Hello Tien, thanks for response.
you are right, the label can be changed by using double click on the part then select the "Label" tab.
I think it would be a beneficial to have the Label field searchable.
please pass it to your developing team.
thanks
Michael
