Multisim and Ultiboard
is it possible to import an ultiboard netlist into multisim?
I discovered today I have accidentally deleted an important multisim file, but i still have the related board designed for it - is it possible to re-create the original schematic in multisim using the exported netlist / ultiboard file?
thanks
Philip
(4,888 Views)
Hi Philip,
You can not import an Ultiboard netlist back into Multisim.  The best you can do with the netlist file is view the data and figure out with parts connects together.
Look inside the folder where you saved the project, see if there is a file with "security copied" for Multisim, if you see it, drag and drop it inside Multisim and this will open the last saved version of your schematic.  Also, have a look in you recycle bin, hopefully, it's still there and you can restore it.
Tien P.
(4,879 Views)
