08-05-2008 12:28 PM
08-05-2008 04:47 PM
I believe this can be done, but you would need to try it. This is just off the top of my head at the moment .Try creating a part for layout only using the component wizard and don't assign any values to it. You can copy one of the symbols from the database for the symbol of this part. Also do not assign a footprint to it. This will make it a virtual component and will not (hopefully) be transfered to Ultiboard.
I hope I have understood what you need and I hope this works. Let me know if it doesn't and I will examine it further.
08-05-2008 08:31 PM
08-05-2008 08:32 PM
08-06-2008 05:03 PM - edited 08-06-2008 05:06 PM
Great to see you found a better solution. I had forgot about the variant manager since I have rarely had a case to use it. As far as tranfer I would have to test it to be sure, but I do believe it will exclude it from export at least to Ultiboard unless it is the active varient at the time of transfer.
Just a quick note. If you create a blank component with no model it will not simulate and should not effect the netlist as it would appear more or less invisible to the simulator. It would treat such a component as an open circuit. I thought you might want to know this information just for reference.
