02-13-2015 04:50 AM
Hi all of you
I'm using Multisim 12.0 to do personal research in electronic. In the present lab, I multiply the sinusoidal and square signals using AD633AN component (U8) and the circuit works fine. But when the square signal is complemented before being used in AD633AN (U1), the transient analysis fails with a 'time step too small" error.
Please, kindly help me to fix this issue.
circuits in jpeg and Multisim format are attached.
02-23-2015 02:52 PM
It seems like the digital inverter is causing the convergence problem. I replaced it with two sources and go the circuit to simulate.
02-24-2015 10:37 AM
Hi Tien
your are right. but problem is that I have to use for the two multipliers the square signal and his inverted at the same time.
the circuit does not walk when I use the inverted signal.
