10-09-2014 09:16 AM - edited 10-09-2014 09:26 AM
Sorry-did the double messages
10-09-2014 09:18 AM - edited 10-09-2014 09:28 AM
Hello.
There was a small problem. Multisim software versions (10 and 13) calculates the value of the polynomial at a particular point in a different way. In what could be the problem..???
At this point should be -3, 553mV.
10-10-2014 04:48 AM - edited 10-10-2014 04:49 AM
Hello.
Multisim Version 13 (13.0.995) makes a mistake in the construction of a negative number to an odd degree. Sign of the resulting number is still positive for the template record exponentiation. If a negative number multiplied three times consecutively, the result will be correct.
Or this problem is known and has already been solved .. ???
10-13-2014 12:38 PM
Hi Vlad,
It looks like there is a problem with the ABM calculation; I will ask the developer to look into this problem.
10-13-2014 02:30 PM
Thanks Tien!
The same problem and in Multisim version 12.
10-14-2014 03:58 PM
Hi Vlad,
Just tested this in V12 and it's also a problem.
10-15-2014 03:03 AM
Thanks Tien.
When the developers fix this problem .. ??? ... how soon will the patch .. ???
The issue is not related to this topic ...
How do I create Multisima SPICE model and connect it to the animation (eg heating of metal) ... ?? SPICE model, I do, but how to make animation .. ?? Maybe there is a guide .... prompt.
10-15-2014 08:34 AM
Hi Vlad,
I am not sure when our developers will fix this problem, there are factors like what resources are available, the defect severity and are part of the decision when things get fixed.
Animated components have custom code to make it behave a certain way and it's hard coded. A user does not have the ability to add animated parts in Multisim
