03-19-2015 02:46 PM
I want to acquire a signal from a photodiode, which its output is as current, in the following: you can find the link of that.
I'd like to know which type of connection should I select?Differential or single-ended?
Petar
03-30-2015 11:21 AM
Hi Petar2015,
I am unable to see the link that you intended to use, so I don’t know very well which photodiode you are using. In the following link, you should be able to find a little more information about the different ways to wire inputs.
http://www.ni.com/white-paper/3344/en/
I would recommend you to use the single ended to acquire input of current. But if I were you, I would read through the document and analyze the ways to connect it with the diode you have.
Luis C.
Applications Engineer
03-30-2015 03:33 PM
