12-22-2010 02:27 PM
The software I'm trying to install is Multisim component evaluator Analog Devices edition, version 11.0.1. Everything has gone smoothly except that when I reach 'features to install', the list is blank. The installation summary says 'No software will be added or removed', and the 'next' button does not highlight, leaving me stuck. How do I get a working installation?
12-23-2010 09:52 AM
Your description sounds like you are using XP 64 and this is an OS that we don't support, Vista and Win 7 64 bit are supported.
12-23-2010 12:32 PM
Bingo, and argh...
03-27-2013 03:37 PM - edited 03-27-2013 03:38 PM
on multisim 11.0.2
i have the same problem on a pc with windows 7 64 Bit.
if i try on a partition on the same pc with Xp Professional the installation is ok.
03-28-2013 12:34 PM
You should be able to install 11.0.2 on Win 7 64 bit, this probelm only applies to XP 64 bit.
11-24-2014 08:06 PM
some one to help on how can i get those compents in multism 11.0.1 i have installed as evaluator
11-28-2014 09:18 AM
The component evaluator doesn't have the instruments you mentioned. You have to get the professional version for this instrument.
You can refer to the feature table from the following address for more information about the features in various editions.
http://www.ni.com/white-paper/5609/en/
11-28-2014 01:22 PM
thanks but how can i get the proffesianal version
12-01-2014 10:46 AM
Hi there,
You can find more information about the Professional Edition of Multisim at:
