06-03-2009 04:17 AM
I'm trying to install Analog Devices' version of Multisim, however when I do it instantly responds with a "is not a valid win32 application" error message. Any ideas on how to fix?
Cheers,
Phil
Solved! Go to Solution.
06-03-2009 04:21 AM
06-03-2009 09:54 AM
I haven't heard of this error before, so some extra information would be helpful.
What version of Windows XP are you running? Do you have Service Pack 2 or Service Pack 3?
When is this error happening? Is this happening when you run the installer or when you run Multisim?
Last, when this type of error occurs, Windows usually logs some additional information about the error that can be helpful in diagnosing the problem.
1. Open the Control Panel
2. Double click on Administrative Tools. Then double click on Event Viewer.
3. On the left, there are several items. Look select these and look for any Errors at the same Date and Time you tried to start the program (there will be a lot of unrelated items but they are in order with the most recent at the top). For each Error that has the same Date and Time
- Double click on the item.
- Copy and paste the Description into your reply.
06-03-2009 10:57 AM
XP SP3.
Instantly after I click the installer.
And there are no errors for the application. The error is so instant, I doubt it would even get that far.
Phil
06-03-2009 03:12 PM
I had forgotten that the download is contained in a self-extracting zip. Are you able to extract the installer or are you not even getting that far?
Could you also post the MD5 sum you are calculating?
06-04-2009 04:31 AM
No, not even getting that far. I open the exe I downloaded and instantly it fails.
MD5 = 49560808913E1AF4D1B677B28C92FEDF
Phil
06-04-2009 07:49 AM
06-04-2009 08:13 AM
Huh! Downloaded on another PC and its fine!!!
Sorry!
Phil
