12-28-2009 04:37 PM
I found a Spice balun model in the attached pdf from designers-guide.org. I get no output (but also no erros when I run a transient analysis on it. Does anyone see why?
Thanks.
12-29-2009 10:39 AM
Hi David,
This one's quite easy to fix. What is happening is that when you are copying and pasting from the PDF, the negative signs are interpretted as dashes instead of negative signs, and there is a difference! It is quite easy to fix.
That should fix the problem.
Happy holidays and hope that helps.
12-29-2009 07:09 PM
Thanks, Works as expected now. I could have looked at that for the rest of my life and not seen it.
David B
