03-23-2015 04:33 PM
I'm trying to create a footprint for a 168-pin connector, the pads have a dimension of 0.3x1.1mm with a 0.5mm pitch.
The problem is that I need it to have vertical pin numbering starting from lower left.
When I use "Renumber.." from the Tools menu I get the numbering in pairs of two. It works as expected with a lower pin count with different spacing/size.
Any ideas on how to solve this or what I am doing wrong? Naturally I want to avoid numbering the pins manually.
Thanks in advance
03-26-2015 10:02 AM
Hello grafi,
Can you share an Ultiboard design that contains the newly created footprint?
This should make it easier to see what is going wrong and where it is exactly going wrong.
