06-26-2009 03:33 AM
Hello Paul,
my colleague tested this with exact the same version that you have. I made some screenshots with the exact steps that I am doing. In case it doesn't work, can you try this with a new design? Just create a new design, place some components and try to change these attributes.
Are you using the full or the power pro edition?
06-26-2009 06:25 AM
It is working with a new ultiboard file and place directly the components in ultiboard.
But when you use multisim and transfer --> transfer to ultiboard 10 (or Forward Annotate to Ultiboard 10) your methode won't work anymore.
07-02-2009 12:50 AM
Hello Paul,
we did some further testing with examples from Multisim; when transferring those examples to Ultiboard we see the same problem in 10.0, when doing this (with the same examples) in 10.1 we are able to make the values visible.
This is an issue which is related to your version and has been resolved in the latest version. Unfortunately there is no work around.
07-02-2009 01:17 AM
