02-26-2009 03:27 PM
My Ultiroute has suddenly started giving me a "Please check your User Authorization" error message when I try to route a board. Ultiboard runs fine, the internal rip-up router seems to be OK, but Ultiroute won't run any more. I can't find any way of dealing with this. The software is Ultiboard 2001 SP2.
Thanks!
03-03-2009 08:48 AM
Let's try this:
03-03-2009 12:54 PM
Fernando,
Does this mean I will need a new release code, or can I use the same one as previsously used, since my hardware configuration should be the same? I guess I'd really like to know what exactly happened here, rather than just re-install everything blindly.
03-04-2009 02:37 PM
You should be able to use the same Release Code if your hardware configuration hasn't changed; anyway if for some reason you have issues with this, just use the Online Release Code Generator to get a new code.
Ultiboard/Ultiroute 2001 are products that we don't support anymore, therefore I won't be able to tell you what caused this error.
03-04-2009 02:59 PM
Fernando,
I haven't yet tried this, as at this point, it's not critical, and I have other things I need to get done. However, when schedule permits, I'll give it a shot. In answer to your questions:
1. I haven't tried the re-install
2. No
3. XP SP3
4. Ultiboard 2001 Power Pro
Dave T.
