NI Home > Community > NI Discussion Forums
Circuit Design Suite
Do you mean
Reply
Member
Re: This circuit has no power sources: unable to determine the simulation timestep automatically.
I really need you help. I've bought a book with a Multisim 10.1 Student Edition.
When I want to simulate something, I receive the following error message:
"This circuit has no power sources: unable to determine the simulation timestep automatically.
Please add a power source or set the simulation timestep under "Interactive Simulation Settings" to proceed."
I am using Windows XP.
Some time before I downloaded Evaluation Version from NI website and had the same problem.
Thank you for your help.
Best,
Anis
Member
Hey guys, Lacy and Devon_H,
I was facing the same problem each time I tried running my circuit. And every time I get this error : "This circuit has no power sources: unable to determine the simulation timestep automatically."
So I need to know if you fixed up thiss issue or if I need to reinstall the program.
note I've tried my circuit on my freind's Pc and it seems to functoin normally
I'll attach the circuit and the error msg
Active Participant
Can you post your circuit so we can try to figure out what is causing the issue.
Tayyab R,
National Instruments.
Member
hey,
I've attached the cicuit and named it error
btw just whant to mension it again that i tried my circuit on my freinds PC  and it worked fine.
Also i tried to uninstall the program from the control panel but it remained, so i tried to erase it from its file locarion but some folders remained there and know i cant even reinstall it :s
Active Participant
I do not see the attachments. Can you please try to attach the Multisim file again.
Tayyab R,
Member
Hey this is the circuit along with the Error msg
