02-22-2010 05:43 PM
03-04-2010 04:12 PM
Hi there,
I have not see this issue before, but perhaps your filters were not set to allow selecting attributes prior to using In-Place edit?
If you post a file that contains the issue, I can look into it for you.
03-04-2010 04:46 PM
Unfortunately I haven't been able to reproduce the problem either. Perhaps I did have the filter off and didn't realize it either.
I will update this thread if I come across the issue again.
03-09-2010 04:40 PM
I have a project now that reproduces this problem.
I'm afraid I can't attach the file here since there is some proprietary information. Can I create a support request? We do have a maintenance agreement with NI for this software. Can you remind me how to create the request? I click support, and then "service request manager." However, I see a screen that says "Please complete the form below to continue or log into your existing profile on the right." I add a phone number, click continue and I'm direct back to the same page.
Thanks.
03-09-2010 04:50 PM
The workaround is actually NOT clicking in-place part edit, but rather showing the copper top layer. Some of the REFDES silkscreen text is not selectable until I fill the "1 Copper Top" check box in my layers bar.
To reproduce the problem in my design I,
1) Hide all layers but "Silkscreen Top" and "Soldermask Top"
2) Clear all filters but "Enable Selecting Attributes"
Now I click the text "R23" and no selection box appears.
3) Show the "1 Copper Top" layer.
Now I can click the text "R23" and a selection box appears.
4) Partially show the "1 Copper Top" layer (greyed check mark box)
Now I can no longer click the text "R23"
As a test, I have place some parts on the bottom side of my board now. The same behavior is exhibited, only now in order to select the REFDES text I must now toggle the "6 Copper Bottom" layer to full on.
03-15-2010 03:49 PM
I'm not sure if you got support, but I want to make sure we find the cause of this issue. I tried your latest reproduce steps, and unfortunately, I cannot reproduce the problem.
If possible, could you remove all components from your board except R23, and see if it still reproduces with that board? If it does reproduce, would you be able to post that file.
03-15-2010 04:04 PM
Here you are.
Thanks for looking at this for me.
03-16-2010 08:59 AM
Thanks for posting the file. I can now see the problem, and I've entered a bug (D117067) so that it may be addressed in a future release.
I do have an additional unrelated question. In the file you posted, I noticed the layer "KeepOutLayer" but this layer will not actually keep out anything (at least automatically). So, I'm wondering how you created the layer (software and import file format) so we can take a look to see if we can do a better job importing this information.
03-16-2010 09:46 AM
I'm very happy you were able to replicate this. I was worried that it had something to do with the way I was copying components to my corporate database.
I see "Keep Out" and "Keep-in/keep-out" layers in my design. They were automatically created when I transferred my design from Multisim to Ultiboard. Inspecting my full design I don't actually see any shapes or lines on that layer. I do see two boxes on the "Courtyard Layer" around quad opamp TSSOP-14 packages.
